My RV-8 build
Date:  3-16-2013
Number of Hours:  1.50
Manual Reference:  Page 8-24
Brief Description:  Tailcone assembly #2
Part 2 of 2 today
After clecoing the bulkheads and skins together, I setup a few boxes to keep the assembly in place while I worked it into the mid aft section of the fuselage.
I removed the clecoes from the bottom skins and the sides of the skins on the F-807.
I carefully moved the longerons and skins into place and clecoed may way around the bottom skins and the side skins.
Once the skins and longerons were secured, I clecoed the F-808 to the baggage rib assembly.
I then placed the lower skin into postion and clecoed from front to rear, ensuring the bottom skin was sandwiched between the lower longeron and aft skins.
The skins are a little thicker at the rear and lining the holes up took a little extra work, but all is good.
I'll be bending the top longerons soon.
Bottom skins and aft skins clecoed in place.
Interior shot of the rear fuselage.
Another angle,
Another angle,
